Help with workstation build
Go to solution Solved by 19_blackie_73,
1 minute ago, Claytality said:
Cheers blackie
Do you know of smaller cases than the Air 240 that could be used for this particular build? I would prefer an even smaller case if possible, but would like to stay within the somewhat same price range. The cooling solution doesn't have to be from noctua either.
how small do you want to get?
I mean, any micro atx case you find will fit the components I chose. But I really like the idea of the air 240 and it's bigger brother, and you chose it too, so i thought why not. Additionally, as the 240 is limited to 120mm cooler height, I did not find a better cooler IMO. I just discovered a mistake in my previous partslist, the psu has sfx formfactor instead of atx. As you are in denmark, you should be able to get bequiet stuff, get the psu i put in the build below.
I mean, you probably could go to ITX, but then you have zero expansion possibilities. Here's a suggestion
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
CPU Cooler: be quiet! Shadow Rock 2 51.4 CFM Rifle Bearing CPU Cooler  ($42.77 @ OutletPC)
Motherboard: Asus Z170I PRO GAMING Mini ITX LGA1151 Motherboard  ($158.99 @ SuperBiiz)
Memory: Kingston Savage 32GB (2 x 16GB) DDR4-2400 Memory  ($173.87 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($94.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: MSI GeForce GTX 1060 6GB 6GB 6GT OC Video Card  ($249.00 @ B&H)
Case: Fractal Design Core 500 Mini ITX Desktop Case  ($49.99 @ Newegg)
Power Supply: be quiet! STRAIGHT POWER 10 CM 500W 80+ Gold Certified Semi-Modular ATX Power Supply
Monitor: Dell U2414H 23.8" 60Hz Monitor  ($228.99 @ B&H)
Keyboard: Logitech G610 Wired Gaming Keyboard  ($93.70 @ Amazon)
Mouse: Logitech G502 Wired Optical Mouse  ($59.99 @ Best Buy)
Total: $1530.07
Generated by PCPartPicker 2016-11-08 10:29 EST-0500
1. Budget & Location
Budget is $1500-2250 - Location Denmark
2. Aim
Used as a workstation for hobby photo/video editing and sound recordings.
Prefer small form factor and I need wifi either via expansion or motherboard.
3. Monitors
Only have room for 1 monitor and would like to have an IPS monitor.
4. Peripherals
All peripherals are needed. Will not need OS though.
5. Why are you upgrading?
Looking to replace my laptop
My proposed setup - http://pcpartpicker.com/list/zTGGxY
https://linustechtips.com/topic/686908-help-with-workstation-build/
11 hours ago, Claytality said:
Julian - Sadly this doesn't fulfill the small form factor wish
CPU Cooler: Noctua NH-L9x65 33.8 CFM CPU Cooler  ($46.95 @ Newegg)
Motherboard: Asus MAXIMUS VIII GENE Micro ATX LGA1151 Motherboard  ($199.99 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Case: Corsair Air 240 MicroATX Mid Tower Case  ($84.93 @ B&H)
Power Supply: Silverstone Strider Gold 450W 80+ Gold Certified Fully-Modular SFX Power Supply  ($87.98 @ Newegg)
Keyboard: Logitech G610 Wired Gaming Keyboard  ($94.02 @ Amazon)
Total: $1699.09
Generated by PCPartPicker 2016-11-07 02:43 EST-0500
I have optimized your partslist a bit. You may profit more from a faster quadcore than such a low end xeon with 2.1GHz. (+ you might be able to overclock the 6700k quite a bit.)
If you are not gaming that much, you might even consider a 1440p monitor or you even might be able to get a 1070 and a 1440p monitor. (sth like that: http://pcpartpicker.com/product/BpgPxr/dell-monitor-u2715h), but that depends on the prices you have in denmark
EDIT: put your wifi card back in, forgot about that part
Edited by 19_blackie_73
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
Cheers blackie
Cheers blackie
Cheers blackie
Total: $1530.07
- Ryzen Build -
2x Dell UP2516D
