Hi there,
So a few years back, when I was young and naive, I decided to get a gaming rig. Not a gaming rig I built myself but a gaming rig built by Alienware, I know..
However after a two years of having a great time it started to act up. Now after 1,5 more years I am looking to upgrade, if possible. I have no idea if it's possible to upgrade an Alienware desktop and if I can use the same motherboard. But I simply don't have the money to buy a whole new rig. What parts should I replace and what should I keep?
Thanks in advance,
2Girls1Dirk
Ryzen 5 5600x
MSI x470 gaming plus
Asus rog strix 580
https://linustechtips.com/topic/686761-need-help-with-upgrading/
Wat. A 4770 is Very fine still.
Replace the 670 with a used 980 or something and you are golden .
Edit: oh and get a SSD.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/686761-need-help-with-upgrading/#findComment-8817428
The problem is, the tower of this Alienware is really really small, so I will have to get a new tower aswell probably. However I am a bit hestitant to take out the original motherboard and put it in a new tower.
Edit: Oh yeah and that's why I haven't bought a SSD yet because it just doesn't fit.
Ryzen 5 5600x
Asus rog strix 580
https://linustechtips.com/topic/686761-need-help-with-upgrading/#findComment-8817443
