Hi,
I recently bought a physical copy of Battlefield 1 as in the disc. When I launch the installer, a window pops up saying click continue, and when I do that the window closes and nothing happens. I'm really confused on why this is happening and at the same time really keen on playing so can someone please help me.
https://linustechtips.com/topic/686140-battlefield-1-having-problems-installing/
7 minutes ago, Yuhandong said:
Yes Origin is installed but the only code that came with the game is a hellfighter pack or something
I take that back. There is a code that redeems the game, however it only has a download button and no option to install off the disk. I would just download it, but I don't have unlimited data.
wait, so you don't have a package for internet? o.O
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
http://answers.ea.com/t5/Origin/How-do-I-get-BF1-to-install-from-the-discs-rather-than-download/td-p/5640847
you could try instead of using the disc going onto Origin and putting in the Download key
once you put in the download key you should be able to download it straight off the internet without the cd
Insert   Dank   Signature   Here.
I do not wish to download it off the internet as my I don't have an unlimited data plan. 40gb is alot and on top of that the disc would be faster.
