Need help With skyrim
Go to solution Solved by Joelbanks5,
2 hours ago, Kavaton said:
Yeah that was the problem, thank you :)
No problem, I'm pretty sure now that your problem is solved you must use the marked solved thing. For me it's a little check mark underneath the post of the user.
That happened to me when I literally first got in the game. They were talking and when we got to the gates they wouldn't open. I think you have to mess around with its settings in GeForce experience. Make sure your frame rate is stuck at 60FPS that was my problem as I had my monitor at 144
you can look look other places too that already have the answer
https://linustechtips.com/topic/685668-need-help-with-skyrim/#findComment-8806463
https://linustechtips.com/topic/685668-need-help-with-skyrim/#findComment-8806754
