Beginner problem.
Go to solution Solved by elpiop,
The srand function takes an unsigned int as a parameter. You're trying to pass in char *, which is what the error is saying. I think you just need to use 'time(NULL)' instead of ctime(NULL). Ctime converts the time to a character string, when srand() needs just the time as an unsigned int.
When I try to run this code I get the error: 'void srand(unsigned int)': cannot convert argument 1 from 'char *' to 'unsigned int'
and under it
 argument of type "char *" is incompatible with parameter of type "unsigned int"
The language I am coding in is C++.
Here's a pastebin link to my code:
http://pastebin.com/cMBQdDGp
(Feel free to criticize as I'm new to coding and I want to learn how to code clean code :D)
https://linustechtips.com/topic/685554-beginner-problem/
https://linustechtips.com/topic/685554-beginner-problem/#findComment-8805282
Wow. Thank you. I never would've know that c in c time meant character time if you hadn't said anything.
https://linustechtips.com/topic/685554-beginner-problem/#findComment-8808262
