the drive makes an intermittent clicking sound that is continuos for up to 5 minutes, the drive is a 1TB seagate constelation oem HP drive
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/684885-possible-failing-drive/
@Captain_WD may be able to help you :)
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8798015
ok
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8798027
Just now, KOMTechAndGaming said:
ok
Usually posts late in the night but he's the person to go for if your hard drive is behaving weird.
Computer Specs:
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8798029
Or quite simply it's early indication of a failing drive?
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8798185
ok in was curoius becuase it makes alot of noise
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8798330
3 minutes ago, scottyseng said:
You can get Seatools and run the Long Generic Test. If it survives, you're good. Try the short test first just to see if it passes or not.
i think im just gonna go buy some new drives (i have one not being recognised by elementry os or win 10)
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8798399
12 hours ago, KOMTechAndGaming said:
~snip~
Hi there :)
As the guys pointed out this may be a strong indication that the drive is on its way to failing so I would strongly recommend backing up your data from it.
Then I'd get a tool from the manufacturer's website and see if the drive passes all diagnostic tests.
Try getting the raw values of the S.M.A.R.T. status with a couple other tools to verify the status of the drive.
Try moving the drive around the case and test it externally to exclude simple resonance with the case as the potential source of those sounds. Sometimes HDDs are not mounted properly and resonate with the case or another part and produce excessive noise.
It's really important to back all your important data up at this point so you don't face data loss issues and data recovery situations.
Thanks @Energycore for mentioning!
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8800544
15 minutes ago, Captain_WD said:
Hi there :)
Captain_WD.
I'll just get the a new HDD and clone it,  what 2TB drive is reasonably priced  but fast
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8800563
WD Blue is a pretty good option for an everyday storage HDD. Let me know if you need more details around this drive.
Captain_WD.
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8800579
Captain_WD.
Thank  for you replys :),  wwhat's the difference between the back and blue drives?
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8800665
Most notable difference is warranty.  The black drives tend to have a damn good warranty (5 year) compared to the more normal lengths for the blue drives (2 year).  Also black drives should (used to) have higher capacities available.   I'm guessing some minor internal differences that sets the performance apart?
For what it's worth.  I've had good experiences with HGST drives in the past.  Currently using a pair in RAID 1 for media duties.
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8800781
Just now, Monte_Carlo said:
Most notable difference is warranty.  The black drives tend to have a damn good warranty compared to the more normal lengths for the blue drives.  Also black drives should (used to) have higher capacities available.   I'm guessing some minor internal differences that sets the performance apart?
I'm thinking of getting a 2tb drive
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8800782
1 hour ago, KOMTechAndGaming said:
~snip~
WD Black drives are designed for performance, more extensive and heavier workloads, multitasking and feature a longer warranty. These drives are recommended for workstations and systems that sustain heavier and longer usage. They have an integrated dual-core CPU that enables the drive to work much better during multitasking.
WD Blue is an everyday storage drive designed for mainstream usage with shorter warranty compared to WD Black but it should also be able to handle pretty much anything you throw at it.
You should be OK with either of them :)
Captain_WD.
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8801001
Captain_WD.
thank you for your advice :)
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8801502
Interesting, I didn't know a CPU inside a hard drive was a thing.
Who manufactures it? Is it proprietary?
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8808825
On 4.11.2016 г. at 10:30 PM, Litargirio said:
~snip~
Hi :)
Every drive has a processor that manages the caching that it does. WD Black features a dual-core processor that offers twice the processing power to maximize drive performance. This enables WD Black to perform better during extensive and heavier workloads and during multitasking.
I'll check if I can share other details around this and will post back. :)
Captain_WD.
https://linustechtips.com/topic/684885-possible-failing-drive/#findComment-8821431
