Posted November 2, 2016 Hi, So I have been asking about various coolers over the last couple days probably getting quite annoying I apologise but I have one last question I can get a Corsair H115i with Eloops for the same price as a Swiftech h240x2 now I have read bad things about both people saying the corsair leaked on their system and that the pump is noisy. I have heard some pretty bad things about the swiftech leaking as well on release however it's been out almost a year now so I would expect most of the issues it had to be fixed by now? anyway my question is what is the quieter option out of these two and does anyone know if the swiftech issues have been fixed now? Custom PC: Intel Core i7 5960X | GTX1080 Strix | 64gb 2400mhz DDR4 Corsair Vengeance Ram | Samsung S951 256gb M.2 | 4TB WD Blue SSHD | EVGA Supernova G2 1300watt PSU | Acer XB270HU | Corsair K95 RGB | Corsair M65 RGB | Link to comment https://linustechtips.com/topic/684704-final-cooler-decision/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2016 Ive had so many problems with the h100x series that i have just never got an aio since. Ive either gone custom loop or budget air cooler since. Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480 Link to comment https://linustechtips.com/topic/684704-final-cooler-decision/#findComment-8795788 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2016 Author 19 minutes ago, ITheSpazI said: Ive had so many problems with the h100x series that i have just never got an aio since. Ive either gone custom loop or budget air cooler since. I currently have a custom loop with a D5 pump and black Ice rads but it has leaked 4 times this year I replaced the cpu block and it stopped for about 2 months now it's leaking from 2 different places so i've got fed up with leaks so I have bought a smaller case and looking for a more simple cooling option Custom PC: Intel Core i7 5960X | GTX1080 Strix | 64gb 2400mhz DDR4 Corsair Vengeance Ram | Samsung S951 256gb M.2 | 4TB WD Blue SSHD | EVGA Supernova G2 1300watt PSU | Acer XB270HU | Corsair K95 RGB | Corsair M65 RGB | Link to comment https://linustechtips.com/topic/684704-final-cooler-decision/#findComment-8795797 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
