I have a EVGA GS 550W PSU and i want some custom cables.
I want these https://eustore.cablemod.com/product/cablemod-e-series-g2-p2-basic-cable-kit-black-red/  These are in the 'E' series. The same as my psu but it says it doesn't support the GS?
If I do use them for my psu will it not power up or? Seems to me like cable mod doesn't really support my psu for the cables that I want, I don't want to use the custom config if I don't have too!
https://linustechtips.com/topic/684214-cable-mod-question/
These are not compatible with your PSU. Most likely different connectors. I wouldn't suggest trying, might kill your system.
These however are compatible with your PSU - https://store.cablemod.com/products/?filter_series=e-series&filter_models=gs-ps-550-650
EDIT: Apparently EU store does not offer them, but the global one does. These also ship to EU, so no worries there. Might be at different rate though.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/684214-cable-mod-question/#findComment-8789987
The thing with EVGA is that they don't have a set standard of their own for their cables. So if a series is based on a different platform from another OEM, then chances are, it will not be compatible. EVGA has Super Flower (B2, G2, P2, T2, as well as the new G2L which has a completely different connector as well) Seasonic (GS, PS), FSP (750B1, G1, GQ), HEC (BQ). Meaning there's likely five different set of cables.
You need to find the proper one for your particular unit.
https://linustechtips.com/topic/684214-cable-mod-question/#findComment-8789998
Any coupon codes xD
https://linustechtips.com/topic/684214-cable-mod-question/#findComment-8790043
