Hey, i''m looking for a cheap build for VR ( Vive ) and i'm in the UK.
While I want a cheap build for VR, I don't want a shitty build, if that makes sense. This PC will only be sat in a room, and it will not be used much outside of VR, as I already have a personal rig, hence why I don't mind cheaping out on stuff.
For example, i'll get a cheap PSU, but not a £20 PSU that will explode in 1 month.
Ideally, it would be the bare minimum, a cheap mobo, cheap HDD, cheap PSU, cheap RAM , etc.
 I'm more or less decided on the case ( S340 elite, it has a nice setup for VR with the front HDMI port and the headset stand ), and the graphics card has already been bought.
I'm not experianced with mid range builds, so i'm not sure what to go for. I'm thinking the I7 6700 and I have a KFA2 1070, but i'm not sure about the rest. I'd be upscaling the vive's reoslution by 1.5 - 2 if possible.
While I appriciate all input, please take into consideration the following things before recommending anything:
I am getting a brand new KFA2 GTX 1070 with my vive. It comes at only a £200 additional cost with the vive, which is cheaper then a 1060 3GB.
This PC will literally be sat in my living room and rarely used outside of VR. Therefore, I don't need an SSD or anything that isn't essential.
I am not sure how much resources VR uses. Do I NEED 16gb RAM for VR? Do I NEED an I7, will it bottleneck in VR?
Thanks!
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/683095-cheap-build-for-vr-read/
i7 6700 isn't exactly 'midrange' and probably isn't even 'minimum' for VR, but beyond that I'm not sure. I think an i5 would be sufficient for entry level VR.
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/683095-cheap-build-for-vr-read/#findComment-8778593
You dont need an i7 or a 1070 to run VR. Oculus recently released lowered specs, now you only need an i3 and a 960, but steam VR still needs an i5 and RX 480 so I would get that.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/683095-cheap-build-for-vr-read/#findComment-8778597
No, but I would rather an I7 as i'd be running a vive and i'd want to upscale it by 1.5%. To be honest, i'm not sure how much CPU impacts VR performance or if the Vive takes usage of hyperthreading. If CPU doesn't impact my ability to upscale resolutions, and it won't bottleneck my GPU, I could go for the I5 6600.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/683095-cheap-build-for-vr-read/#findComment-8778600
Hey,
I think a i7 is a bit overkill, if you want a budget build. I would recommend this:
Intel i5 6400k
GeForce GTX 1060
450 watt corsair
256 gb ssd for OS/programs
1TB HDD for other things
8GB RAM
some MSI motherboard (B150M-D3H for example)
I hope this helps you,
IgnasVas
https://linustechtips.com/topic/683095-cheap-build-for-vr-read/#findComment-8778601
Just now, IgnasVas said:
Hey,
Intel i5 6400k
GeForce GTX 1060
450 watt corsair
8GB RAM
IgnasVas
Why would he get an Unlocked CPU without a Z170 Mobo?
Don't get an Unlocked CPU if you are not getting an Overclockable Mobo
https://linustechtips.com/topic/683095-cheap-build-for-vr-read/#findComment-8778609
13 minutes ago, IgnasVas said:
Hey,
Intel i5 6400k
GeForce GTX 1060
450 watt corsair
8GB RAM
IgnasVas
Thanks for the input, but :
As I said, I already bought a graphics card ( 1070 )
As I said, I don't need an SSD, I only need the bare minimum.
And, I don't think its worth getting an unlocked CPU with a motherboard that doesn't support overclocking.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/683095-cheap-build-for-vr-read/#findComment-8778635
