UPS required, needing recommendations.
Solved by scottyseng,
14 hours ago, BobbyG2 said:-snip-
I think a 1500 VA Eaton 5S should work fine for this, or the 5P for a bit more efficiency.
Your PC should pull a fair lot of power, I predict 600-700W, maybe more. I kind of don't recommend running the UPS at max capacity even if you only need a really short run time.
