I downloaded the newest version of Geforce Experience and its has been nothing but trouble. I start it up takes at least 15 minutes to start, then it spas' out and notification comes up "Please Restart Geforce Experience". I don't know why its being a bitch to use, worked great before the update. Please help me if you can!
https://linustechtips.com/topic/682274-geforce-experince-30-does-not-work/
Have you tried reinstalling it
I had a couple of issues with the new Gforce experience. I ended up uninstalling it through safe mode and then reinstalling the program after downloading the new one from their website. I also updated my graphics card drivers at the same time. It is now working. I was a pain to be honest. I hope that helps.
If this error occurred during a Driver update you need to go into your control panel and uninstall EVERYTHING with Nvidia on it. Then go into Program Files, Program Files (x86), and your C: drive root and delete all Nvidia folders there.
Then reboot and reinstall GeForce Experience.
i7-6700k OC'd 4.5Ghz, Noctua NH-D15, EVGA GEFORCE GTX 1070 SC
