USB Problem
Solved by NeoFrux,
5 minutes ago, zanthros said:I don't understand why you awarded yourself "Best Answer" as @Runefox gave you the answer. Kind of self serving don't you think? Maybe next time you come here with a problem you can have a conversation with yourself and fix it yourself with no help from anyone else and deserve giving yourself the best answer.
Ehh, I kinda shotgunned my answer either way. @REDDEATH's more accurately describes the solution, so I think this is most correct for future generations looking for a solution, which is what the solved button is for.
