When i put my gtx 1070 in the system i get no post screen at all with display port plugged into either the mobo or gpu. When i take the gpu out, the system boots just fine. I get no post screen or anything with the gpu in but when i take it out i boot into windows or the bios.
Psu: rm650
https://linustechtips.com/topic/680537-pc-wont-post-with-gpu/
do you have multiple PCI slots in your motherboard? if so try a few out. also, you can try booting to windows and installing the drivers for you 1070 manually. i would also check the power supply cables to make sure that they are working, or just switch them out for different ones. make sure the graphics card is seated properly and all the cables are snug. if all else fails, they do sell tech amulets in japan, maybe one of those will help?
https://linustechtips.com/topic/680537-pc-wont-post-with-gpu/#findComment-8752271
Psu: rm650
well obviusly it disables the mobo port asoon as a Dgpu is installed , did you get the Card new? it might be a doa
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
https://linustechtips.com/topic/680537-pc-wont-post-with-gpu/#findComment-8752280
