HDD info required!
Go to solution Solved by ARikozuM,
Just now, titaniumshield said:
What if we all watch different movies because there is a high possibility.Are Multiple drives the only solution?
There might and adding more drives would be one way to increase performance.
4 minutes ago, titaniumshield said:
Hi everyone
I was wondering what happens when multiple users on the same network access a file from the same HDD at the same time. Does it effect performance when users stream data from that particular HDD and
The controllers do a good job of getting the data off as best they can. The data will simply go from the platter to the DDR module on the controller through the SATA channel into your system's RAM for use. If you're going to have multiple users I'd suggest going with a RAID array (I prefer 5) so that multiple drives contain the same data.
damages the HDD in the long run?
Mechanical stress kills HDD's. There's no way around it except to lessen the stressors. But no, reading and writing don't hurt drives.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/679238-hdd-info-required/#findComment-8738202
I understand but i have a budget for only one drive. What if i increase the RAM amount rather than an extra drive? Will that help?
Keep it simple.
https://linustechtips.com/topic/679238-hdd-info-required/#findComment-8738211
No. You're going to be fine though serving multiple users with one drive for a while. Unless all users are trying to watch different movies, performance should do well.
You can also buy cheap server drives and run them in RAID.
Edit: Adding more RAM doesn't help as you won't be filling it fast enough for the drive to make use of the extra RAM.
https://linustechtips.com/topic/679238-hdd-info-required/#findComment-8738228
Keep it simple.
https://linustechtips.com/topic/679238-hdd-info-required/#findComment-8738234
https://linustechtips.com/topic/679238-hdd-info-required/#findComment-8738245
