13 minutes ago, Haydenp10 said:
I need help with getting a mic stand which works on my desk
My desk is too thick to support the clamp for an average mic stand so what can I do to get something that goes on my desk so I can have a mic stand
how thick is your desk?
"I take great pride in my humility" -Me
My Steam Profile (from SteamDB)
  • Worth: $1614 ($629 with sales)
  • Games owned: 126
  • Games played: 111 (88%)
  • Hours on record: 3,483.3h
https://linustechtips.com/topic/678806-mic-stand-help/#findComment-8733996
I know that rhode sells a microphone boom that has a mount you directly drill into the desk.
  • Games owned: 126
https://linustechtips.com/topic/678806-mic-stand-help/#findComment-8734004
https://www.amazon.com/dp/B001D7UYBO
These are very nice. They have two desk mounting options. One is clamp, the other is.... suction cup? Not sure. Check it out.
See here for one in action:
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/678806-mic-stand-help/#findComment-8734031
they are really kind of expensive though
  • Games owned: 126
https://linustechtips.com/topic/678806-mic-stand-help/#findComment-8734042
Yes, too expensive
https://linustechtips.com/topic/678806-mic-stand-help/#findComment-8738006
3 hours ago, Haydenp10 said:
Yes, too expensive
worst case you could jerry rig it a bit
  • Games owned: 126
https://linustechtips.com/topic/678806-mic-stand-help/#findComment-8738547
