Actually in some other forum there was someone who tested lots of setups. Push Pull was only 1-2C cooler so it's not really worth it.
If you want to go push or pull is up to you. It makes basically no difference.
edit: here you go http://www.overclock.net/t/1199135/hyper-212-testing-push-vs-pull-vs-push-pull-also-horizontal-vs-vertical-positioning
https://linustechtips.com/topic/6788-hyper-evo-212-push-and-pull/#findComment-74199
If you're using pressure optimised fans you will see almost no difference. with cheap fans you will notice. I have a 212+ with the stock CM fans I noticed about a 8°C difference with push pull than just Push. I put on a single NF-F12 and I dropped another 2 degrees. with 2 NF-F12's the temperature didn't drop at all.
Stock CM fan Push 55°C
Stock CM fan's Push Pull 47°C
NF-F12 Push 45°C
NF-F12's Push Pull 45°C
Prime 95 on small fft for 30 mins before I took temps.
Ambient was around 24°C ± 1°C
CPU is Phenom II x6 1090t
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/6788-hyper-evo-212-push-and-pull/#findComment-74484
