Hey everyone so i just bought a GTX 1080 and i was wondering how / whats the best way to overclock. i had issues with CSGO where my frame rate was quite low in comparison to others and the parts i had so i wondered if this might make a difference.
Speccy gave me these results: are these normal?
Current Performance Level    Level 1
Current GPU Clock    607 MHz
Current Memory Clock    405 MHz
Current Shader Clock    405 MHz
Voltage    569.500 V
Bus Interface    PCI Express x16
Temperature    26 °C
Driver version    21.21.13.7306
BIOS Version    86.04.17.00.01
https://linustechtips.com/topic/678439-overclocking-help/
14 minutes ago, dexxterlab97 said:
How much fps are you getting? CS GO is a cpu intensive game
200 on dust 2 with a i7 6700, is still lowm, i saw bench marks hit 500 and the weird thing is no matter the res 2K or 720p or high or low settings its always the same FPS
https://linustechtips.com/topic/678439-overclocking-help/#findComment-8729721
50 minutes ago, smokefest said:
CS GO a CPU intensive game ?!?!?!?!
CS GO can be maxed out with a fuckin Q6600 and a gtx 750ti eaaaasily in 1080p
You dont need an i7 6700k and a gtx 1080 for cs go lollllll
You can acutally play cs go on a 200$ pc and max it out
Are you trolling or being ignorant? Just because I have good specs doesn't mean it was for CSGO only, I play CSGO and expect higher FPS, I have my specs because I want to play other games in 4K, I wasn't asking your opinion for a different build for CSGO.
https://linustechtips.com/topic/678439-overclocking-help/#findComment-8730423
u mad ? I smell sand in the pussy.
I just found this "  How much fps are you getting? CS GO is a cpu intensive game  " funny.
No need to get mad little guy, peace
https://linustechtips.com/topic/678439-overclocking-help/#findComment-8730429
200 fps isnt enough really in CS:GO. 300 is much more smooth. Also, lets try and take people's topics seriously and leave the childish banter on other forums.
As for you OP, try overclocking your CPU a bit as thats what helped me. Another thing you can try is making sure your preference is set to performance in the Nvidia control panel.
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
https://linustechtips.com/topic/678439-overclocking-help/#findComment-8730867
