Looking for a picky fan controller
Go to solution Solved by W-L,
3 minutes ago, jaccep said:
-SNIP-
It depends on the fans your using if they are PWM 4 pin fans you can use the CPU header and get a powered splitter, but for 3 pin fans something like the NZXT Grid +V2 would be ideal for this situation.
Hello all!
I know there are a handful of similar questions in this forum already, but I'm looking for help with a short list of issues that I'm hoping to solve with a single device. I have a small media PC in a Core V21 case that for reasons I'm looking to use air cooling for the time being. The mATX Gigabyte 78LMT-USB3 motherboard I have only has 1 fan connector aside from the CPU fan.
What I want to do is A.) Use my 1 fan port for 2+ fans. B.) Not have each fan running at 100% constantly. C.) Not use a fan controller that requires a front case slot as the core v21 doesn't have any. and D.) Ideally have it be some sort of small fan controller that fits inside the case and can have the curves be set via software.
Is there anything out there that fits these criteria? I appreciate the help.
https://linustechtips.com/topic/678138-looking-for-a-picky-fan-controller/
-SNIP-
