You have 2 SSD and 1 TB Hard drive.
SSD#1 you installed Windows and SSD#2 you installed Mac OS and the 1TB Hard Drive is for your other stuffs like Music, Games, Pictures, ETC.
is it possible that you disable SSD#2 to use Windows 10 or disable SSD#1 to use MacOS? and use the 1TB Hard Drive for both.
Because if this is possible most likely i will use Windows just for Gaming and Recording and some stuffs and for Mac OS i will use it only for school.
documents, editing videos, rendering videos, syncing apps iphones or ipads.
Planning to build
i5-6500
GTX 1060
https://linustechtips.com/topic/676989-dual-boot-system/
Any discussion of hackentoshing is against the community standards.
If you installed two seperate OSes onto different drives when you boot it will default to one of them, but there should be a key to press to go into the boot options where you can pick a drive to boot from, usually at the bios splashscreen it will pop up.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/676989-dual-boot-system/#findComment-8713455
