hi, im gonna be using 780t with a 360 in the top and 240 in the front, i dont know what fans to use for the 360 rad they will be in pull and exhaust , the front will be intake and i want to put 3 120mm fans in the front to increase airflow since watercooling, and i want to set it up for postive pressure, also what fan hub should i get, the mobo i want comes with enough for 3 fans and i will need another for the front 3, im gonna be using ekwb rads and all that, i was thinking the EK vardar fans but is there any alternatives that are simmailriy priced (£15-20 per fan)
many thanks
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/676918-radiator-fans/
Check out the Corsair ML120's, excellent fans, probably just edge out the Vardar's overall.
Do you need a fan hub? You can run x3 fans of a motherboard header with a splitter. If you want a hub, the Aqua Computer Poweradjust is supposed to be very good (there are a few variations on it, with differing features).
System: Ryzen 7 5800X - Gigabyte X570 Aorus Master - Noctua D15S Chromax - 32GB 3600 RAM - EVGA Black 2080Ti
https://linustechtips.com/topic/676918-radiator-fans/#findComment-8712531
well there will be 7 fans with the possibility of 10 total, i would like for it to be easier to control the speeds
https://linustechtips.com/topic/676918-radiator-fans/#findComment-8712533
1 minute ago, belfouf said:
I've put gentle Typhoon (Nidec) in push and Thermaltake Riing in pull, very efficient and nice looking. You can also go for EK-Vardar F3-120 in push, they're nearly as good
interesting, im going for a black, blood red(coolant colour), with white accenting (fittings)
https://linustechtips.com/topic/676918-radiator-fans/#findComment-8712544
can you get photo of the thermaltake fans?as in real life :P?
Edited by KOMTechAndGaming
https://linustechtips.com/topic/676918-radiator-fans/#findComment-8712551
They are great but have to be PWN controlled for normal good performance. If not they seem to behave not to good I think I saw mentioned in several reviews.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/676918-radiator-fans/#findComment-8712558
2 minutes ago, belfouf said:
nice, and i can get a pack of 3 for aroud £40(thats cheap for fans assuming £15-20 per fan)
https://linustechtips.com/topic/676918-radiator-fans/#findComment-8712566
interesting, i need to get a fan controller similar to this http://www.phanteks.com/PH-PWHUB.html
https://linustechtips.com/topic/676918-radiator-fans/#findComment-8712570
well there is a 3x pack with a hub controlling RGB colors for 50£, but if you just need one color then yes I think 4x£ is enough for three
https://linustechtips.com/topic/676918-radiator-fans/#findComment-8712618
I bought this hub for my Gentle typhoons, they are 3 Pin and it allows the use of PWM on them. It works, but not as well as real PWM fans (can't get them to run as slow as with a 5v resistor)
https://linustechtips.com/topic/676918-radiator-fans/#findComment-8712625
