So I'm building my first PC for gaming mostly and I'm wondering which cpu is better paired with an Asus ROG Strix RX 480: the I-5 6500 or the FX 8350/70. One note though, this is just a temporary cpu and i'm getting an upgrade next year.
CPU Intel Core-I5 6600K OC to 4.4GHz MOBO MSI Z170A Gaming Pro Carbon RAM 16GB Kingston HyperX Savage DDR4-2400MHz GPU Gigabyte GTX 1060 G1 Gaming 6GB
Cooler Cooler Master Hyper212 Evo PSU Corsair RM650x 650W Boot drive Kingston v300 120GB SSD Storage WD Blue 1TB 7200rpm HDD Case Corsair Carbide Spec-03
Extra NZXT Hue+ LED light controller + 2xNZXT Aer 120mm RGB fans
https://linustechtips.com/topic/676837-first-build-cpu-dilemma/
The 6500 is a better CPU.
Only grab a FX-83XX if it's $110 or less
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/676837-first-build-cpu-dilemma/#findComment-8711756
Since your not looking for a long term option until next year, I'd honestly get even an core i3 and cheap mobo. Save your pennies for the new AMD CPUs/Mobos coming next year. They are making some serious waves in testing already and from what you can read around the web, they may just finally give Intel a good punch or two. :)
https://linustechtips.com/topic/676837-first-build-cpu-dilemma/#findComment-8711783
7 hours ago, Jorgen297 said:
If it's temporary, get the 6500 and a Z170 board, then get a Kaby lake i7 next year which should work on the Z170 board with a bios update. I know ASUS has a bios update already.
Is it going to be good enough to run Battlefield 1 on high 1080p? With the RX 480
https://linustechtips.com/topic/676837-first-build-cpu-dilemma/#findComment-8712656
How is Zen going to compare to kaby lake in performance and price? Cause I'm more of an AMD guy so i'm thinking on going w Zen, but i don't want to get outdated hardware, even for a year, if it's possible to get better.
https://linustechtips.com/topic/676837-first-build-cpu-dilemma/#findComment-8712667
8 hours ago, wrathoftheturkey said:
Once you factor in the fact that he's upgrading next year, even this wouldn't be worth it since he'd have to buy new RAM.
Eh one can sell used RAM at 80% value because RAM just doesn't die (exceptions apply)
Computer Specs:
https://linustechtips.com/topic/676837-first-build-cpu-dilemma/#findComment-8712844
The 6500 shouldn't bottleneck the 480, and if it does, it will bottleneck considerably less than the 8350/70.
Yes i get that, but will it be able to play all of the latest games, especially BF1, on 1080p high settings on constant 60fps or more?
https://linustechtips.com/topic/676837-first-build-cpu-dilemma/#findComment-8714956
