Phanteks Enthoo Pro cooling
Go to solution Solved by WoodenMarker,
18 minutes ago, azza_01 said:
do you guys think if i add two extra exhaust on top will make it anyworse or better ?
It would probably help cooling.
That being said, you should see how your temps are before deciding on whether or not to buy new fans.
Hey guys i need some advice on getting the best case cooling for build i plan on doing. I will be using the  Phanteks Enthoo Pro  Case. It comes with 1X  200mm intake fan  FRONT, 1X 140MM EXHAUST REAR. Im thinking to add 2 X 140MM EXHAUST TOP.  Considering that my  CPU intel stock fan cooler and video card as both as intakes will his cooling be good. As far as i think my theory goes that this should create a neutral type pressure. Having a even of 3X intake fans and 3X exhaust fans . What do you guys think ? be appreciated cheers.
Video card: MSI GTX 1060 ( Twin Frozr VI cooling )
CPU: I5 6500 (WITH STOCK FAN)
Case fans i intend to add:  2X PH-F140SP, a 140mm Premium fan
https://linustechtips.com/topic/676238-phanteks-enthoo-pro-cooling/
I have this case and im using the fans that came with it, they are pretty decent. Im using an H105 which is mounted up top exhausting air. But I would reall suggest an after market CPU cooler.
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
There's need for an aftermarket cooler on a 6500 or more fans.
The stock fans should already be fine.
True, as long as he is ok with his temps. but a cheap CPU cooler isnt a bad idea, a tower cooler will help move air better?
The stock cooler is plenty for keeping temps in check for a 6500.
There will always be better cooling options but having more than necessary doesn't really do anything.
are your temps high? is this why your asking?
exhaust on top is a bad idea. it starves the cooler of airflow. i was running exhaust with the stock cooler and i hit ~80C under load. swapping the fan to intake dropped it to ~75C
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
