Hello Linus people,
Im having issue with my alienware 15 R2, Which is:
When I enter game without connecting the AC adapter, all my USBs disconnect randomly.
I have followed some steps which are disabling suspend settings from power plans, device manager "power management" thing and updating BIOS and still facing the same issue.
Anything from your side I could try??
https://linustechtips.com/topic/676153-usb-randomly-disconnects/
Stop kicking things around while gaming... My first gues would be that your USB devices get a bad connection, due to quick/jerky movement on your part. (if gaming on a flat/stable surface, without moving the laptop, I would think it's something else)
And my gues for this is... While connected to the AC adapter, you might be more aware of cables >>> less jerky movement.
https://linustechtips.com/topic/676153-usb-randomly-disconnects/#findComment-8704487
My laptop on a table, I use Razer ouroboros gaming mice; I have reflashed it and still the same.
https://linustechtips.com/topic/676153-usb-randomly-disconnects/#findComment-8704493
Possibly a power draw issue, jump through your laptops manual, some of the dell's I've had don't supply much power to usb when unplugged from the ac.
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/676153-usb-randomly-disconnects/#findComment-8704525
