I'm having some strange issues with Spotify, which I think might be caused by the drivers for my Logitech G35 headset. If I'm playing music and I start up a game, the music will stop playing and I will be unable to start it again, even if I try to play another, different song. Spotify just gives me the message "Can't play the current track." This is fixed by restarting Spotify and isn't really a major issue, but I find it odd since these issues have started happening recently and in conjunction with a total loss of sound in X-Plane 10. Windows also sometimes shows an error saying "Windows has detected that drivers for this device are causing issues" or something similar, can't remember exactly ATM.
I have tried reinstalling Logitech Gaming software, making sure that all traces of the program are gone before installing again. The issue is fixed for a while (and sound in XP10 returns) but swiftly returns.
Does anyone know what is causing this? I'm looking at maybe upgrading my CPU/mobo in the future, which requires reinstalling Windows, which might fix the problem.
“sufficiently advanced technology is indistinguishable from magic still going to require driver rollbacks when it stops working for no reason“
https://linustechtips.com/topic/676145-very-strange-sound-issues/
maybe its some kind of DRM protection? spotify thinking you tried to record it or something i dunno.
If it worked after a clean/fresh install of the drivers, try doing it again. And then disable all driver updates for that software/product. Maybe an hidden update is causing the issue.
Secondly, with windows 7, I once saw an option where I could allow/deny only one piece of software to acces a sound card... Maybe that could give you a hint @ windows 10?
Will try this later.
