Now perhaps this isn't a question for the gearheads but could someone please tell me what the hell these weird paint imperfections are?! It looks like diamond grip steel! what could that be? these have been there since I got the car! (note: I am painting the hood and it is the only place where they are.)
  • CPU: AMD Ryzen 2700X
  • Motherboard: MSI X470 Gaming Pro
  • RAM: 32 GB HyperX Fury DDR4 2400
  • GPU: MSI 5700XT MECH
  • Case: Fractal Define R5
  • Storage: 1TB WD Black 7200 RPM HDD, 2TB WD Black 7200 RPM HDD, 4TB WD Black 7200 RPM HDD, Samsung Evo 960 1TB SSD
  • PSU: Corsair CX750M
  • Display(s): HP 24W
  • Cooling: 1 120mm Corsair fan, Noctua NH-U14S
  • Keyboard: Razer Blackwidow 2016
  • Mouse: Razer Deathadder Basilisk.
  • Sound: Razer 7.1 Kraken Chroma V2, LG SJ4Y 300W soundbar
  • Operating System: Windows 10 Professional 64 bit
https://linustechtips.com/topic/676117-gearheads-help-2/
That's textbook cracking, a lot of things can cause it.  Anything from prolonged exposure to sunlight, extreme temperature changes, or improperly mixed paint can cause it.  When you remove the old paint, sand through most of the primer too in case any moisture got through the top layers.
https://linustechtips.com/topic/676117-gearheads-help-2/#findComment-8705565
