You could try a Noctua NH-L9i, but I don't know how much difference it would make.
Edit - Lol - I just notice the "besides the L9i" part. :)
Edit #2 - I wouldn't worry about the 75C too, too much if it's only "bursts" under load. But, make sure your thermal paste is properly applied. You could try removing the cooler and re-doing the thermal paste - not too little, not too much. :)
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/674622-mini-itx-cpu-cooler/#findComment-8688756
12 hours ago, Mi26 said:
Wrong choice to overclock in small form factor build
I haven't even over clocked yet and don't decide to. The K version is just future proofing.
I'm thinking to get Be Quiet's Shadow Rock LP.
https://linustechtips.com/topic/674622-mini-itx-cpu-cooler/#findComment-8691529
