10 minutes ago, Neo0152 said:
I have a old Dell inspiron n5040 that i got from a friend for free and i bought more ram put i tried installing it and just keep getting a blue screen
the new ram is this https://drive.google.com/open?id=0ByZ7mNwewMzfeEtLODJzVmlpSFE
If it is a windows bsod then what is the error code, it literally could be almost anything without knowing the code.
Also if it boots then you got the correct ram type.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/674268-ram-upgrade-neeeeed-help/#findComment-8683933
11 minutes ago, Neo0152 said:
where did you get that from
Dells website . * I selected your laptop and chose upgrade options and the first option was ddr2 my bad. I guess dell wont filter results that will actually fit the product you are looking up.
https://linustechtips.com/topic/674268-ram-upgrade-neeeeed-help/#findComment-8683938
https://drive.google.com/open?id=0ByZ7mNwewMzfUlQ3WnNBTTFjaDQ tis is what i got
https://linustechtips.com/topic/674268-ram-upgrade-neeeeed-help/#findComment-8684000
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/674268-ram-upgrade-neeeeed-help/#findComment-8684050
7 minutes ago, Neo0152 said:
so does that mean i wasted by money
Most likely a faulty ram stick, RMA it, and if accepted the manufacturer will send a replacement.
https://linustechtips.com/topic/674268-ram-upgrade-neeeeed-help/#findComment-8684116
