Hi.
I'm going to have a new cooler for my new processor.
My processor is a i7 6700k, and my plan is to overclock it.
I have a Corsair 760T case, and i think i am going with a AIO cooler.
Corsairs website says that the case support 240, 280 and 360mm. fans on the top but it that right. (I am new to cooling ;))
I have looked at Corsair H115i, Corsair H110i, Corsair H100i v2 and nzxt kraken x61.
I'm not sure if my case supports the coolers, so I hope that you can help. Maybe you also got some suggestions.
Maybe you also have some suggestions where to place the cooler (fan direction.)
I don't know i it's to overpowert to go with a AIO cooler but I want the processor to stay cool. (AIO coolers looks better :)
Thanks in advance.
https://linustechtips.com/topic/673222-cooling-help/
I would recomed a 280mm radiator in the front, with the fans in a push config (fans mounted to the case, and radiator mounted to the fans)
Remove the airflow fanst that are there from stock, they are not good for radiators.
I have a corsair H45 and it is noisy as fuck, i hope the higer end models are quieter.
https://linustechtips.com/topic/673222-cooling-help/#findComment-8673323
