H115i Problems here D=
Go to solution Solved by pyrojoe34,
3 minutes ago, Mikealongo said:
I have it like the image here: https://imgur.com/a/WTpzq , is that temp 33.1 the water temp?
And if it is, i dont know what fan curve to use (i guess that temp dont fluctuate ass the cpu temp, but what i want is to keep the cpu cool, dont i?)
I put push/pull because i saw some vids where the temp goes 2 or 3 degrees lower, i know that is overkill for my cpu xD but as i said, it was like a nightmare to build it (just the aio, im fine with the oder partes when building it) so im not planning to change it in a near future xD
Yes 33 is the water temp, but if your water temp is not increased then running the fans faster will not do anything to cool your CPU, the fans only cool the water, not the CPU. That's how liquid cooling works. The water will warm slower than your CPU, that is normal. Fans on a liquid cooler don't work like fans on an air cooler. That's why you base your fan curve off the water temp and not the CPU temp.
Hi everyone,
Yesterday i put the H115i into my system, y configure it in push pull by adding 2 sp 140 mm fans into it going from:
to:
But i have some problems to configure that:
1- The H115i only comes with 2 fan connectors to a one fan conector (CPU one) so the other 2 (the led ones) are connected to the case fan controller; Can i buy a splitter and conect them to the other cpu fan connector?, in that case, will it run at the same RPMs?
2- The H115i is way too loud even if i set the quiet mode... i set a custom fan curve but i dont know if its good enough for the 3770 non k:
      35ºC   -   25%
      45ºC   -   35%
      60ºC   - 100%
Could be that my fan setup is conflicting with the H115i?
Would you suggest me antoher fan curve for the 3770 non k?
If you see some problem with my built just tell me, i want it to be in an optimal configuration.
Thank you all =)
https://linustechtips.com/topic/673202-h115i-problems-here-d/
Suggest you return it and swap it for a NZXT Kraken x61. Performs better, while also being able to run with less noise then Corsair + it's cheaper.
But for both you might have to tinker a bit with fancurve. But these AIO's are a expensive overkill for a noc OCable CPU in my opinion, so whats your reason for swapping from air to liquid? Looks, room around CPU?
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673155
Are you running AIDA64 or HWinfo? Read my signature for the fix.
If you just mean that the fans are loud at idle (700rpm i think) then that's because the stock fans suck and you'll want to replace them. If the problem is that the speed doesn't match the fan curve and fluctuates randomly then the fix is in my sig.
Also, you are setting the fan curve to the water temp, not the CPU temp right? It should not be based off the CPU temp.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673253
Both, because the room around the CPU give me the option to change RAM and because i can watch the ROG logo xD
Im only using CAM and link now an i have them at 1020 rpm now.
Its set to the cpu pakkage i think, but the cpu temp fluctuates allot, and the fans rpm too, i dont know if thats because of a poor made fan curve or why
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673292
Don't set it to the CPU package, set it to the H115i temp. Also read my fix if you're having fluctuation issues.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673296
But that temp is the water temp or what temp XDDDDDDD, it set by default to the package temp, what fan curve should i use with ir?
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673304
In Link there should be a temp under the H115i temp (example) (in mine it's the one under h110i GTX that is the temp of the water in the AIO. That is the temp you should base your fan curve off of since that is what is actually being cooled by the radiator/fans, not the CPU directly. I make a custom curve based off that temp.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673417
Also push/pull is overkill. Just leave it at 2 fans. The difference is nearly unnoticeable and you're making your system way louder.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673441
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673571
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673582
:o im starting to understand it, Thanks!!
In that case im really lost about tthe fan curve XD, should i use the performance, balance, quiet ones or create a custom one?
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673599
Create a custom one. I'm not near my PC so I can't show you mine but I have the curve start at 35C and max out at 50C (at 40C it's about 40%). Starting gradually and then increasing quicker with 50C being about 90%. That keeps my CPU below 62C and the water temps below 46-47C. It also keeps the fans slow most of the time when they're not needed.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673612
Thank you, you make my life quiter xD, just one more question about wc: If water temps are under cpu temps the cpu will transferr heat to the water till the water reaches the same temp, so tue CPU cooling is just the heat transfer between water and CPU, then Why is some WC solution better than others?
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673655
A lot of reasons, more effective heat transfer from CPU to block, and block to water, and more effective heat transfer from water to rad and rad to air just to name a few. For example the water temp of a smaller cooler might have an idle water temp of 40C while a larger has an idle water temp of 30C (It can never be lower than room temp though) because the larger radiator can dissipate more heat to the air. Since the water temp is cooler it can more effectively draw heat away from the CPU. A larger cooler will also heat up much slower.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673707
Ohhh okay i understand, thanks =)
https://linustechtips.com/topic/673202-h115i-problems-here-d/#findComment-8673911
