Hello everyone
Recently I'm having issues with my x58 ud3r rev 1.6 motherboard.
Firstly it was fine. I over clocked my i7 to 4.2 GHz with ezz but when I updated my bios the problems began. The system is perfectly stable but when I shut it down it restarts again!
Anyone know what's happening.
https://linustechtips.com/topic/670104-x58-ud3r-loop-problem/
Just now, farazahmed said:
Hello everyone
Probably an issue with your OC, I recommend jumping the BIOS (Assuming you have checked all the cable connections and etc.)
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/670104-x58-ud3r-loop-problem/#findComment-8640823
1 minute ago, farazahmed said:
Hello everyone
I have tried to downgrade the bios and clear the CMOS but no luck :C
https://linustechtips.com/topic/670104-x58-ud3r-loop-problem/#findComment-8640824
