is your hard drive connected?
 or working?
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
5: RAM upgrade, i want 16gb of black ram
order 1-5 is what I want the most,
color is of importance (most to least)
https://linustechtips.com/topic/669679-need-some-help/#findComment-8636758
1 minute ago, BLUEBERRY said:
Yes
Although I'm inclined to believe you, my 10+ years of technician experience tells me this is a boot device issue.
Does your computer start intermittently, ie: can you power cycle it and eventually it boots? Or is it permanently stating this when you power it on?
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/669679-need-some-help/#findComment-8636774
go into your bios (spam f2 or del right after turning on the laptop) then see if your HDD is showing up in it.
or change the boot order to boot from the hdd first
but i think you need a new hard drive /ssd whatever your laptop has seems like yours is dead/dying if it will boot sometimes but not others
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
https://linustechtips.com/topic/669679-need-some-help/#findComment-8636776
It's permanently stating that when it comes on
https://linustechtips.com/topic/669679-need-some-help/#findComment-8636802
Then you dont have a working boot drive connected. If you are positive all of the ca les are properly connective, the the drive is probably dead.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/669679-need-some-help/#findComment-8636812
Alrighty, that's not a good sign. How old is your PC? Did you custom build, or is it pre-built?
And do you have a way of reading hard drives externally, like a SATA to USB adapter, or external drive enclosure?
https://linustechtips.com/topic/669679-need-some-help/#findComment-8636816
It's was that's a prebuilt computer it's about a three and a half years old that I started added graphics card and power supply and new cpu yes I can check it on a other computer
https://linustechtips.com/topic/669679-need-some-help/#findComment-8636839
Then do that - remove the hard drive, and hook it up to another computer using a USB to SATA adapter or enclosure.
If you still can't access it, the hard drive is dead or dying. You can then either send it out for data recovery ($$$) or move on and replace it.
https://linustechtips.com/topic/669679-need-some-help/#findComment-8636872
I'll try that thanks for ur help
https://linustechtips.com/topic/669679-need-some-help/#findComment-8636918
