I'm building a PC for the first time and I need help deciding if the parts I'm looking at are good and finding some parts that I'm not sure about. I'm planning to use the system for mostly gaming and some work with video editing, probably in Adobe Premiere or something similar.
So far my parts list is: (USD)
http://pcpartpicker.com/list/jNDdbj
I already have a Intel 535 series 240gb SSD to use as a boot drive so I don't need to buy an SSD, and I'm flexible on most of the parts listed there, as this is just my initial inclination based on very little experience.
My budget is somewhat flexible within ~$100 but somewhere around 1300USD
I already have a mouse and keyboard and one 1080p monitor, but I am planning to buy a used 1440p monitor in addition that will not be coming out of my budget for the computer.
Any feedback or suggestions for better parts would be greatly appreciated (I would like to stick with Nvidia and Intel though).
https://linustechtips.com/topic/669185-first-time-pc-build-help/
ok, a few things here:
1. Do you plan on overclocking? That CPU and that cooler are great for it, but the motherboard would need to be a Z170 chipset.
2. That's an expensive case, if you're sold on it, I understand, but if not, I have other recommendations.
3. I am going to recommend going with the 750W Version of that PSU (EVGA 750 G2) because it is only about $10 more and allows for expandability and better overclocking
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631788
You need a z170 motherboard and the heatsink, its good, but really a hyper 212 will do you justice, for the price. Far as psu goes you are fine with 650w really dont need a 750w psu at all.
EDIT: Might be able to fix a 1080 ill try it out and see for the lols
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631796
I am planning on overclocking because the cooler seems to be withing my budget so why not.
I'm not sold at all on the case, mostly because I don't know that much about whats out there. I just want something that looks alright (preferably with a window) and is built sturdily enough.
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631801
if you are OC than the hyper 212 will do you fine.
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631808
Yeah the motherboard was the thing I was least sure about so I'll switch that out. I don't know much about the hyper 212, I only went with the Noctua because my parents asked that my system not be too loud and I know Linus raves about how quiet Noctua is.
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631813
Noctua fans are quite. Hmm alright
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631816
If you plan on overclocking you will need a Z170 Motherboard.
I would personally recommend the Phanteks P400s (with window). it has a little RGB light on the front, a PSU shroud, and amazing cable management, not to mention magnetic dust filters and sound dampeners.
as for your CPU cooler, I recommend going with a Corsair H60 at that price.
Solitaire.
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631826
Also to add if you want really quite gaming get a h100i that will be very quite xD
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631834
PCPartPicker part list: http://pcpartpicker.com/list/CkVQd6
Price breakdown by merchant: http://pcpartpicker.com/list/CkVQd6/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($59.99 @ Newegg)
Motherboard: MSI Z170A Tomahawk AC ATX LGA1151 Motherboard  ($144.00 @ Amazon)
Memory: G.Skill Ripjaws V Series 32GB (2 x 16GB) DDR4-2133 Memory  ($129.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($69.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 1070 8GB Video Card  ($433.94 @ Newegg)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($74.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($84.88 @ OutletPC)
Total: $1292.76
Generated by PCPartPicker 2016-09-30 16:16 EDT-0400
Solitaire.
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631849
Motherboard: ASRock Z170 Pro4S ATX LGA1151 Motherboard  ($101.88 @ OutletPC)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($65.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.71 @ OutletPC)
Video Card: EVGA GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card  ($644.99 @ B&H)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($39.89 @ OutletPC)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($78.99 @ SuperBiiz)
Total: $1268.43
Generated by PCPartPicker 2016-09-30 16:17 EDT-0400
EDIT: 1080 ftw =p also go on reddit and buy an OEM windows key for $30
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631854
Here is the link to the reddit
https://linustechtips.com/topic/669185-first-time-pc-build-help/#findComment-8631880
