Audio Issue
Solved by PaintChips,
If has a Creative Labs Soundblaster Recon3Di that is a known bug which impacts Windows 8.1/10 randomly under unknown reasons(high CPU, GPU or just a program which crashed while audio was playing, etc), some users find its possible to uninstall the driver and reinstall but Anniversary Update has made it worse. I gave up trying to figure out a solution since the problem is extremely random. Keep in mind it isn't just the Recon3Di, also happens on RealTek based H110, B150, H170 & Z170 boards too.
Personally I don't bother using onboard audio, I use a Focusrite Scarlett 2i2 but then again I do audio work so external audio via USB or Firewire is a normal setup.
