Hiberfil.sys issue
Hi all,
my my issue is the following:
>96 GB RAM in my pc
>hiberfil.sys can only be set to 50% of RAM, so takes up 48 GB of ssd space
>only solution is to disable it, but that also disables fast boot
Is there any way to set it to like 10-20% of total RAM? I'd like to keep fast boot but don't wanna give up all that space.
Thanks
Mark
https://linustechtips.com/topic/667960-hiberfilsys-issue/
3 minutes ago, Domos said:
It does work, but only on a 50-100 range. Else it gives an error.
Fair enough, thought that might be the case.
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/667960-hiberfilsys-issue/#findComment-8618606
