Mouse fix?
By
ibrahimwa1
in Peripherals
in Peripherals
Solved by LukeS,
Email Razer and ask about a replacement. Just remember opening up the mouse intentionally to modify or fix/clean it voids the warranty. (This is the best solution)
Try super glue, duck tape, or buying a new one. There's not that much that you can do. Sorry!
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
