Hi guys,
I need to help mi friend to abandon his laptop and start using a desktop. Could you please suggest a list of components for a small form factor machine?
Budget  ~ 700Euro
Mini or micro ITX form factor
1080p gaming
No overclocks
excluding peripherals, hardware only
Thank you in advance for your suggestions
https://linustechtips.com/topic/666935-small-form-factor-machine/
Cm elite 110 itx case
B150m mobo
8 gb ddr4
I5 6500
Gtx 1060 itx form factor
Corsair cx 550m 550 watt psu (with the white label)
I Could be more specific i know
Okay edit: 1tb hdd and idk if you can get that gtx 1060 in europe for like an acceptable price. I am in holland and they are almost €300 here. This is a bit over budget i guess.
I5 4440//8gb Corsair Vengeance ddr3//Sapphire Radeon r9 380 4gb//ASUS h81m-plus//WD caviar blue 1tb//Cooler Master N200//Cooler Master G500
B150m mobo
8 gb ddr4
I5 6500
Thank you for the suggestions, looks solid to me. I see you use "Afuture" as well :D .
Oh! I just noticed your location. Hi fellow dutchman!
