So I've been consistently been able to overclock my PC to 4.5 GHz and the same voltage each time 1.500, However recently In the new windows 10 update I haven't been able to overclock my PC successfully, when I try to overclock it using AMD Overdrive the way I have before with the exact same settings it comes up with a black screen with only my cursor being able to move around. I haven't been able to overclock since the Update even if that is the problem.
Thanks.
https://linustechtips.com/topic/666695-overclocking-issue/
Use the bios/uefi
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
5: RAM upgrade, i want 16gb of black ram
order 1-5 is what I want the most,
color is of importance (most to least)
https://linustechtips.com/topic/666695-overclocking-issue/#findComment-8605545
