it might just be easiet to dig a line from the two buildings about 2-3 inches deep and run a bunch of ethernet cables through there if you dont know how many devices you want. if you have the modem and router in your house, you may also want to try this, modem(house)--->ethernet cable----->router(in garage)---->good from there)
or modem(house)---->router(house)-------->1-2 ethernet cables to garage. (This one is the best way)
https://linustechtips.com/topic/666031-long-distance-networking/#findComment-8598748
