Hello recently my pc has been acting weird suddenly during gaming or web browsing my audio got all distored and my monitors both werent reciving any input but also my mouse and keyboard went off after some quick research it looked like my windows 10 got corrupted so reinstalled it I had still the same problems random crashes a pc that wont boot. I need help i might think its it related to my psu but i dont know for sure. Also this happed multiple times (see photo's) while booting. Sorry for the bad English
My Specs
Intel I5 6400
Gigabyte B150M D3H
Kingston Fury DDR4 2133mhz (8GB)
Gigabyte windforce 960 4GB
SanDisk SSD Plus 120GB
Cooler master B500w v1
https://linustechtips.com/topic/665974-help-my-pc-is-broken/
have you tried another graphics card?
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
https://linustechtips.com/topic/665974-help-my-pc-is-broken/#findComment-8598138
are you running any overclock?
also try running one ram stick only
PSU Tier list
https://linustechtips.com/topic/665974-help-my-pc-is-broken/#findComment-8598175
it might be that when loading the system into ram on bootup , something is going wrong , maybe try another ram slot or stick
PSU Tier list
https://linustechtips.com/topic/665974-help-my-pc-is-broken/#findComment-8598291
hmm do you have a firend who can lend you a stick ? buying a new one when you dont know if its broken might be a waste of money
if the problem persists w/ another ram stick , the board might have a problem
you might be best of RMA-ing the board or ram , if its not too late
PSU Tier list
https://linustechtips.com/topic/665974-help-my-pc-is-broken/#findComment-8598700
No i untforuntly dont have a friend who can lend me one but are you sure it cant be my psu cause all my parts are pretty new acsept my psu that thing is now about 8 years old and it was used when i bought it that also would explain why my leds and mouse and keyboard also go off when my pc gose bad shit crazy
https://linustechtips.com/topic/665974-help-my-pc-is-broken/#findComment-8600051
hmmm , what make is it ?
@STRMfrmXMN can help you w/ that , he shud have an idea afaik
PSU Tier list
https://linustechtips.com/topic/665974-help-my-pc-is-broken/#findComment-8600064
