Need help deciding a case
Go to solution Solved by TheGhzGuy,
Define S should be the easiest to water cool in, but the Phanteks Enthoo is also a good option for it.
Hey.
I need some help deciding a case for my future build. I want to put in a custom watercooling loop by EK. The 360 pack they sell.
- Fractal Design R5
-Phanteks Enthoo Pro M
-NZXT H440
-Phanteks Enthoo Evolv
-Fractal Designs Define S
Those cases are some cases I liked a lot because some of them have Tempered glass on the side which i love just because it looks so nice. I want the best airflow and watercooling possibilites for my setup.
What do you guys recommend?
Thanks in advance!
https://linustechtips.com/topic/665600-need-help-deciding-a-case/
Just now, BaconRace said:
Which Phanteks case? How is the airflow in the Define S though? Any good.
Derp. I meant to type Enthoo Evolv. The airflow in the Define S is fine.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
Ok. Would you pick the Evolv over the Define S or the other way around? The tempered glass on the Evolv is so tempting but if the Define S is better overall I will submit.
