windows 8, 2 X r9-280x, catalyst 13.11
when i first downloaded catalyst 13.11 (my first one, its a new build) it detected my 2 gpus and i enabled crossfire. However after monitoring temps in msi afterburner after some gaming i saw gpu 2 temp and usage didnt change at all so i checked in catalyst and it said my x-fire bridge is not properly attached, ive changed my bridge and the problem remains, any fixes?
thanks.
Cpu:4670k- at stock.... for now Gpu:r9-280x crossfire Cooler:KrakenX40 MB:mpower SP Ram:8gb hyperX beast
https://linustechtips.com/topic/66560-crossfire-issue/
thanks.
Update to windows 8.1 or try windows 7, the drivers are in beta right now so there are some bugs just wait for proper drivers
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/66560-crossfire-issue/#findComment-909936
Also try a driver for a 7970 as there the same card
https://linustechtips.com/topic/66560-crossfire-issue/#findComment-909946
You need to DISABLE UPLS ONLY, no driver changes or anything like that...
MSI afterburner has it in options, if not you have to google and find the registry values to change to 0
You can Google how to do this.
It will stop the 2nd GPU getting stuck at 0% and not being used.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/66560-crossfire-issue/#findComment-909960
