Hey I'm looking for some help selecting a case in the £60-£100 range (preferably at the lower end but I'm willing to spend more if it's gonna improve the case). So far I've liked the look of the phanteks enthoo pro. The things I'm looking for are: 1 or 2 5" bays, good cooling capacity and a large space inside the case that will be easy to work with (this is my first time building).
Thanks for the help!
https://linustechtips.com/topic/665043-help-choosing-a-case/
I'll pull something up in one second. What's the rest of your build? Maybe we can help with that!
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/665043-help-choosing-a-case/#findComment-8588784
Also, is there a reason you'll need those 5.25' bays?
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/665043-help-choosing-a-case/#findComment-8588802
Well, if you like Enthoo Pro, than why not an Enthoo Pro?
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/665043-help-choosing-a-case/#findComment-8588809
It's an old ish case and I'm wondering if you can get a better case for the price if you look at more recent cases. Not sure if it's missin any features or anything
https://linustechtips.com/topic/665043-help-choosing-a-case/#findComment-8588839
I need at least 1 for an optical drive (I like discs plz don't hurt me) then I'd like to use one to give me more options for front io although it's not necessary. The rest of my build:
CPU: i7 6700k
CPU cooler: to be decided
GPU: Gtx 1080 gigabyte xtreme something or other
PSU: rose will hive 750
Ram: 16gb corsair vengence
motherboard: Asus z170 pro gaming
storage: Samsung 850 Evo 240gb
https://linustechtips.com/topic/665043-help-choosing-a-case/#findComment-8588863
CPU: i7 6700k
Air or Water cooling?
No hate for ODD's from me man ^^ If you need em, that's fine lol
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/665043-help-choosing-a-case/#findComment-8588884
I don't think it's lacking any features, and it id one of my favourite cases.
Maybe take a look at CM MasterCase 5 or Fractal Design Define R5.
https://linustechtips.com/topic/665043-help-choosing-a-case/#findComment-8588899
1 minute ago, Biccers said:
Probably air for now but I'd like the opportunity to install a rad later if I feel like it
Alright, thanks for letting me know.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/665043-help-choosing-a-case/#findComment-8588959
