Hello, it is my first time building a computer, and it will not start. When the system fan is plugged in no fans spin, when it is not plugged in processor and graphics card fans spin. But nothing shows on the screen. None of my leds light up and there are no beeps to indicate a problem. Does anyone here know what might be wrong? Thanks.
Parts:
Case: NZXT S340 Razer edition
CPU: AMD fx6300 black edition
Motherboard: Gigabyte AM3+ AMD DDR3 1333 760G HDMI USB 3.0 Micro ATX Motherboard GA-78LMT-USB3
Storage: Kingston 120gb ssd
PSU: EVGA 500w
RAM: Corsair vengeance ddr3 1600mhz 8gb (single stick)
GPU: EVGA GEFORCE GTX 950 2gb ssc
https://linustechtips.com/topic/664598-i-have-a-problem/
Are you sure that your power supply is on ? I know thats a stupid question, but I forget it myself few times. And are you sure that your power button cables and the other really tiny cables are plugged in in the right connector ?
Edited by Qrko
https://linustechtips.com/topic/664598-i-have-a-problem/#findComment-8583934
So you cannot get the machine to post? i would first check all of the cables and connections, make sure everything is plugged in. there should be a 6+2 PCIE cable plugged into your gpu, a 4+4 ATX/CPU plugged into your motherboard, and a 24 ATX connector also plugged into your motherboard. You should have sata connectors plugged into all drives, both from the motherboard and from the psu. All fans and coolers should be plugged in as well. Next, reseat the GPU and RAM. Move the ram stick between dimm slots.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/664598-i-have-a-problem/#findComment-8583946
I believe all the stuff is plugged in right.  It still will not post, I think it is a broken part. Do you know what part could do this?
Thanks
https://linustechtips.com/topic/664598-i-have-a-problem/#findComment-8588875
Thanks
I would start with the ram. Follow the procedure in my previous post on how to test the ram. If possible, test a second stick, as its impossible to rule out a ram fault without at least 1 working stick. Next, remove your GPU and try booting with the iGPU. You can try testing your PSU with the paper clip method, but that will not tell you if there is a fault with the psu, it will simply tell you if the PSU is able to power on. Testing the motherboard and CPU is a bit more difficult. If you have access to compatible parts, that would be useful. I would start by removing the cpu. Using a magnifying glass, look at the pins on the CPU and make sure none of them are bent. At this point, its either the CPU or Mobo that is most likely broken. Try rmaing the motherboard first.
https://linustechtips.com/topic/664598-i-have-a-problem/#findComment-8589275
