I had my oc stable on 1300 mhz , no v offset. But after while the gpu maxed out at 600. A fresh install of the same driver fixed but after overclocking the same problem came to bite me. I use msi afterburner. And yes ive tried setting my gpu to performance. thanks
XTREME I7 GRANDIS TRIDENT SUPERNOVA ECLIPSE PC++:
CPU           ✧   i7 6700K  @ 4.5 GHz 1.31 VCore
COOLER   ✧   SilentiumPC Grandis
MOBO       ✧   MSI Z170A GAMING PRO CARBON
RAM          ✧   16Gb Trident Z's 3200 MHz
GPU          ✧    Gigabyte GTX 980 ti XTREME
SSD           ✧   Samsung 850 Evo 250 GB
PSU           ✧   EVGA SuperNova G2 650W
CASE         ✧   Phanteks Eclipse P400S [Black]
Use:
✧ Game designing, Programming, Compiling, 3D rendering and of course Gaming
https://linustechtips.com/topic/661883-980ti-core-clock-problems/
What are you doing when you're testing the clocks? Are you running a game/synthetic graphics load? If not then do that as GPU boost has a lot to do with clocks. If the GPU doesn't need to be at it's highest clocks then it won't. My 980ti at desktop sits at around 135MHz core clock. Whereas in games with no core clock offset it manages to reach the 1300-1400MHz range.
1 minute ago, ModerateSkill said:
What are you doing when you're testing the clocks? Are you running a game/synthetic graphics load? If not then do that as GPU boost has a lot to do with clocks. If the GPU doesn't need to be at full clocks it won't. My 980ti as desktop sits at around 135MHz. Whereas in games with no core clock offset it manages to reach the 1300-1400MHz range.
ive ran furmark and valley, still maxes out at 600
Use:
It goes down to 600Mhz under Load?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
weirdly, yeah
Use:
Are either power or utilisation at 100%? Try increasing power limit.
i have. this only happens after i oc
Use:
Just now, Liquid Cooled Human said:
weirdly, yeah
Whats the Card doing if you dont OC it ?
the same but when i re install the driver it goes back to stock speeds
Use:
3 minutes ago, ModerateSkill said:
How are you overclocking? There might be a problem there.
i increase the power limit to 110% then put cor offset to 270 and it works
Use:
Core offset of 270MHz is a bit extreme if I'm not wrong. GPU Boost will try to boost the card up to 1300MHz and what you're telling it to do is try 1570MHz? Try setting the offset to 50MHz. (Please correct me if I am wrong about GPU Boost, I haven't really researched it into too much depth.)
Set the offset to 50MHz and see what clocks you get, and whether they're sustained.
Reinstall a Driver sometimes isnt enough if its corrupt. Delete it with DDU, clean the Registry with CC Cleaner and reinstall the latest Driver. Run a Benchmark for 30 Minutes without OC to see what happens.
my card stock core is 1026, an offset of 270 is normal
Use:
