I am having problem deleting or writing files, I cant format the usb.
So I tried to diskpart with command  attributes disk clear readonly and It did nothing. I even tried regedit and still nothing, maybe im not doing it right on regedit.
Can someone help me with it so I can write to the usb again?
https://linustechtips.com/topic/661318-usb-write-protected/
open disk management and find the disk number your usb is regarded as
then open diskpart in cmd (like before)
then type "select disk X" (X being the number your usb is given)
then type clean (this will nuke everything SO MAKE SURE YOU GET THE RIGHT NUMBER as ive done this wrong before and completely lost everything on my SSD)
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/661318-usb-write-protected/#findComment-8549741
https://linustechtips.com/topic/661318-usb-write-protected/#findComment-8549876
15 hours ago, Ajaydev Singh said:
it might be that one of your Io usb connectors is broken
https://linustechtips.com/topic/661318-usb-write-protected/#findComment-8553096
