I just got a new computer with a
amd fx 8350
Msi gtx 1060
my brother bought battlefield 4 on his PC so i logged into his account downloaded it and tried to play, every 1 - 2 minutes I get frame rate drops too about 10 frames. My gpu is brand new and my cpu is about 5 months old. Please help.
https://linustechtips.com/topic/660384-frame-rate-drops-bf4/
Sounds like a heat problem on either GPU or CPU, most likely CPU.. so Its trotteling, thats why you get the frame drop. I would do a Prime 94 test for your cpu, and firestrike or something like that for your gpu. Post the temps here, and we will see if that is the problem
https://linustechtips.com/topic/660384-frame-rate-drops-bf4/#findComment-8539572
Either heat or PSU problem
https://linustechtips.com/topic/660384-frame-rate-drops-bf4/#findComment-8539576
Or maby you have forgot to to use the 8 pin power connection, usually located on the top or the bottom of the motherboard? if u havvent plugged in that one the PCI express slot / CPU slot, dont get enough power under load.
https://linustechtips.com/topic/660384-frame-rate-drops-bf4/#findComment-8539578
Just now, kameloso said:
do u have a spare PSU to swap over? might be the PSU that dossent give your hardware components sufficient juice. like not a stable enough current. How much ram do you have? maby your ram fills up and dossent clear itself fast enough.
I still would like to see the idle and stresstest temps for your CPU and GPU tho
https://linustechtips.com/topic/660384-frame-rate-drops-bf4/#findComment-8540055
I've got 16gb of ram and I don't think there's anything wrong with the power supply.
https://linustechtips.com/topic/660384-frame-rate-drops-bf4/#findComment-8545735
