i am hopefully building on a lag 1366 platform using either 2 xeon e5620 or 2 xeons x5670 with a dual socket motherboard it is a SuperMicro X8DTL-3F rev2.01 Motherboard server board also with    and i am looking to get registered ddr3 ecc memory.  i do not know what power supply due to the two 8 pin cpu power ports and what case it will fit in and should i do hard drive or ssd this will be my fist build but i am wanting good preformace so i can edit and possibly stream if there is another build about $400 or less that can get me 50-70 fps in 1080p in triple A games let me know thanks
https://linustechtips.com/topic/660084-cool-build-but-need-help/
1 minute ago, K0NA said:
Im using Corsair RM850x 850w in my dual cpu build, and fractal XL case
That is overkill
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/660084-cool-build-but-need-help/#findComment-8536507
2 minutes ago, AwesomeTecher said:
how is this overkill?
Most builds don't require more than 500w. Usually anything over 650w is considered overkill for most builds. Though, for a dual cpu setup that are have a high tdp each, then 850w is not as overkill.
https://linustechtips.com/topic/660084-cool-build-but-need-help/#findComment-8536549
