So I really want to try to get into Linux and I've seen people say that Ubuntu is the easiest to start with.
Problem is, I know nothing about it except the fact that it's amazingly light weight on specs and takes little disk space.
So I was wondering if any of you guys had some words of wisdom for starting a Linux machine like what I should know, or some precautions if there are any. (Also I'm trying to make it a dual boot with Win.7 cause there still isn't enough games on Linux to make me fully switch)
https://linustechtips.com/topic/65970-help-a-beginner-get-started-with-ubuntu/
Do some googling for general Linux concepts. The terminal/command line, directory structure, etc. I don't have any specific links to give you, sorry. The arch Linux forums and wiki are great places to learn about what's happening behind the scenes.
P.S. I would personally recommend Mint over Ubuntu because the layout is more similar to Windows and there isn't so much drama with the development. Also, it is based off of Ubuntu, so everything is compatible.
[spoiler=My Current PC]AMD FX-8320 @ 4.2 Ghz | Xigmatek Dark Knight Night Hawk II | Gigabyte GA-990FXA-UD3 | 8GB Adata XPG V2 Silver 1600 Mhz RAM | Gigabyte 3X Windforce GTX 770 4GB @ 1.27 Ghz/7.25 Ghz | Rosewill Hive 550W Bronze PSU | Fractal Design Arc Midi R2 | Samsung Evo 250 GB SSD | Seagate Barracuda 1TB HDD | ASUS VS239H-P | Razer Deathadder 2013 Partlist
LTT Build-Off Thread: http://linustechtips.com/main/topic/35226-the-ltt-build-off-thread-no-building-required/
Ok thx Ill dl Mint too.
