Just now, bacon W/ eggs said:
Oops, I will be using 4 case fans + 2 cpu fans
If you want 3 pins, you could buy a couple of these:
https://www.pccasegear.com/products/28288?gclid=Cj0KEQjwpNm-BRCJ3rDNmOuKi9IBEiQAlzDJH7Xi2DsXWFwKl9xTYAP3WWHwPVgvMcugdsCXpjXiy3MaAuue8P8HAQ&gclsrc=aw.ds
If you want 4:
http://www.ebay.com.au/itm/like/121405985394?lpid=107&chn=ps
Up to you if you want to pay that much just to get some extra fans. I know I would go with what I said in my previous post.
Which one is more worth it though. I am ready to pay more if it pays off on the long.
1 minute ago, EnemySp0tt3d said:
If you just get a fan controller, you can control all your fans from that controller. It does make life a lot easier when you can control your fans.
Or you can just use a fan curve program instead of outlaying that much. Such as speedfan (not sure if Speedfan does fan curves)?
What fans and motherboard do you have?
