so as i was sat on skype i decided to install 2 fans to the bottom of my h100i while the system was running(stupid i know) as i was putting a screw in one of the fans the monitor turned black and wouldnt come back on so i shut my pc down and tried to start it up again but this time it will not start. the digital post code thing will not show any numbers or light up, my keyboard and mouse will not turn on and the pc will not output a video signal so i tried to troubleshoot it. i took my gpu out and tried to boot from the i-gpu but still the same ting so i took one stick of ram out and this time the system will power up for a second then shutdown and if i leave it it does this over and over again with the only difference being that the post code lights up then turns off but only displays 00 before turning off.
does anyone have an idea about what is wrng with my pc?
Parts:
cpu:4690k
mobo:msi gaming 5
gpu:970 ssc
ram:16gb hyperxbeast 1600mhz
psu:corsair rm650x
https://linustechtips.com/topic/658776-pc-will-not-boot/
